Engine Startup - FirebirdV6.com/CamaroV6.com Message Board
Engine Startup
  • Engine Startup
    I know there could be many things, but could someone tell me what to do/check on my bird becausee i got the new engine in but it wont start up.
    Symptoms:
    -Sounds like its not getting gas
    We checked it had pressure and gass in the lines
    Starter Fluid made it turn over twice
    -Short in post O2 cat sensor, lit a small flame, yeah that was fun :omg:
    I havnt really worked on newer cars much but i can run with that off right?
    Unplugged it
    -Has Oil pressure
    -Has Gas...lol:naughty: im not that dumb
    -All A/c components dissconnected, waiting for parts
    -Ask about other things...
    Got any ideas???
    '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
    '99 Firebird SOLD 1/4 mile 15.4 @ 86
    '66 Ford SOLD
    Re: Engine Startup
    turned over as in it started for a sec?
    if so, it obviously a fuel problem. do you have a gauge to see the fuel pressure? are you sure all the fuel injector wiring is hooked up and such?
    2000 3.8 A4 Pewter Camaro
      Re: Engine Startup
      Yeah, it most definitely sounds like a fuel injector problem. Take them out and reinstall them, unless you are positive they are in there good enough and then check your wiring and make sure it is wired correctly and nothing was missed the first go around.
      Good luck, and post any other information you can think of that you may have neglected/forgotten to post the first time.
        Re: Engine Startup
        More and more im thinking FI problem, i guess ill have to retrace the FI wiring.
        Is there a way to run without Post o2 cat sensor in, besides o2 sim, i think that the o2 sim would just short out too. Can i go to a shop and have them delete to code or will it come up again later? i dont really want to rewire all the way under the car, it was a PIA just to get thos wired. If not ill just have my car guy fix it for me.
        '66 Ford SOLD
          Re: Engine Startup
          O2 sims from casper. Warrenty. Id try it if it bugs ya. 02 code will clear but will be back in about 2 days.
            Re: Engine Startup
            the post-cat o2 sensor has nothing to do with your engine not starting!
            I deleted the code on mine... never came back (of course not)
            are you sure you got all the grounds connected to the block?
            I had that problem
              Re: Engine Startup
              check fuses as well.
                Re: Engine Startup
                have some one try starting the car, while you get by the exhaust outlet and see if you smell gas, you should if your car is getting gas. If you dont smell it, your not getting gas and need to checked your injectors.
                  Re: Engine Startup
                  Yeah im sure its getting fuel to the rails b/c we checked, and it fires when we use starting fluid.
                  Would it have anything to do with it now having the '00 rails/injectors not the '99 rails and injectors (there is a difference).
                  What ground is for the FI's?? Anyone know?
                  '66 Ford SOLD
                    Re: Engine Startup
                    maybe you need to tune it for the rails/injectors
                      Re: Engine Startup
                      if that is the problem ill just put my old ones on if i have too...
                      '66 Ford SOLD
                        Re: Engine Startup
                        also, just cause you have fuel doesn't mean you have adequate pressure. :)
                          Re: Engine Startup
                          It shot out like a purge on nitrous i think theres enough pressure.
                          How do i dissconnect the fuel lines without spraying it everywhere? Since i cant just disconnect the fuel pump and kill it.
                          '66 Ford SOLD
                            Re: Engine Startup
                            i would just pressure on the valve with a rag covering it until the pressure is released.
                              Re: Engine Startup
                              fuel pump relay will kill your pumps pumping pumpability. There will be gas....lots of it. Dont hang under that **** when you release it, even with a towel. gas tastes nasty :eek:
