Ok, this all started about a week ago. My back driver's side tire, as best I can tell, whenever there was diagonal force on my tire like if I'm going diagonally downhill, if I turn, etc. It sounds like its the little metal pieces on my brake pads that make that loud screaching sound when my brakes are about to run out are scratching my disc somehow, but I dismantled my brakes and there is plenty of pad left, probably more than half the life left on them, I didn't see anything at all wrong with it. Now that I ****ed with it though its squeeking like twice as bad, but when I get going on the highway it seems to go away unless I go over a bump it'll squeek as my tire vibrates from the bump.
Also when this problem came up, whenever I put my car in reverse there is a bad bad bad sounding squeeking noise coming from the front of my car whenever I put my car in reverse, I'll try and get more info on this cause I need someone to stay outside and listen when Im backing up slowly. It doesn't sound exactly the same, though, this sound actually sounds much worse, but as far as I can tell isn't affecting anything either... Does it sound like I ****ed up my suspension or something?
As far as I can tell though its not affecting my braking at all, my tries aren't wobbling or anything, lol, its just really annoying sounds... I just hope my tires dont fall off on the highway next week or something... :(
Anyone have any ideas?
[ March 22, 2004, 02:17 PM: Message edited by: Golbez ]
