numb arm - FirebirdV6.com/CamaroV6.com Message Board
numb arm
  • numb arm
    :p so im checkin my coils and i got the shock of life like 20 times haha So how do i tell if a coil is bad? Most of them are like purplish and my number 2 and 5 cylinder coil are orangy colored So would that cause the motor to sputter at all throughout the rpm range!?
    Re: numb arm
    ya it would
    my coils were bad and it sputtered
      Re: numb arm
      how much do they run about?
        Re: numb arm
        ~$20 at autozone...
          Re: numb arm
          for 1?
            Re: numb arm
            have AZ test um for ya for free.....
              Re: numb arm
              you probably lost like 1/2 of your brain cells. better put in a claim on your life insurance, they might kick you down a couple thousand.
                Re: numb arm
                haha Yeah when I was listening for misfires with it running I pried a screwdriver under the plug wire by the coil to pull it off and see if I heard it drop off and I had no gloves on. Did not feel good. Neither did carb cleaner in my eyes.
                  Re: numb arm
                  lmao i was wearing gloves tho and the pliars i had had electrical tape around the two little tong things and i still get shocked like crazy .. It felt good and bad at the same time .. its hard to explain haha But yea are the coils hard to switch out?
                    Re: numb arm
                    What are they called exactly so i can look for them online. Ignition Coils?
                      Re: numb arm
                      coil packs or ignition coils are the common terms to search for
                      http://www.bowtiev6.com/
                        Re: numb arm
                        sick thanx brotha
                          Re: numb arm
                          dont touch or lean on the car wile your doing it and you shouldnt get shocked since your not grounding to the car
                            Re: numb arm
                            oh no wonder why haha i was leanin on it haha
                              Re: numb arm
                              i leaned all over the car when i changed mine...i didnt get a shock?
                              87 Firebird RIP
                              96 Camaro RS RIP
                              94 Patriot Red 1LE Z28 - Sold
                              02 WS6 TA - Sold
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
