I have a 1999 and the blinker is out. I have found the housing unit for the blinker but I can't seem to figure out how to dislodge it. Is there some special button that I should be pressing for it to release?
How do you remover the front blinker bulb?
Red \'99 3.8<br />Induction: SLP Cold Air Intake, K&N Air Filter, Whisper Lid<br />Ignition: Taylor Spiro-Pro Wires, Bosch Platinum 2 Plugs<br />Suspension: Power Slot Rotors, Hawk HPS Pads, Mille Miglia MM11-2 18x9, Goodyear Eagle F1 GS-D3 245/40-18Tags: None
If it's the little 194 bulb, you just have to twist it and it will come out. If it's the 3157 bulb then you have to push in on the side of the bulb harness to twist it in order to get it out. If you feel around on it you should be able to feel what you need to push in. It's a real PITA to do. Just kind of feel it out, and good luck.- JT3<br />1998 Red V6 Camaro Y87 Y3F - J.E.T. Chip Stage II - Clear Parking Lights - Removed Grill - K&N - Whisper Lid - !FRA MOD - MAF Screen Removed - Pro 5.0 - Pacesetter Headers - Magnaflow Catback - 32mm Front Swaybar - And A System(bump bump)
It's the 3157 bulb. So you push it in (towards the front of the car) and then twist? Or where the wire meets the housing you push it in there and then twist?Red \'99 3.8<br />Induction: SLP Cold Air Intake, K&N Air Filter, Whisper Lid<br />Ignition: Taylor Spiro-Pro Wires, Bosch Platinum 2 Plugs<br />Suspension: Power Slot Rotors, Hawk HPS Pads, Mille Miglia MM11-2 18x9, Goodyear Eagle F1 GS-D3 245/40-18
I attacked that blinker from the underside of the car cause there was just NO way from the hood. Who ever said it was a...... "SOB to change." Amen to that. The space you have to work with is way small but I was able to change it in about 5 min.
Thanks fellas.Red \'99 3.8<br />Induction: SLP Cold Air Intake, K&N Air Filter, Whisper Lid<br />Ignition: Taylor Spiro-Pro Wires, Bosch Platinum 2 Plugs<br />Suspension: Power Slot Rotors, Hawk HPS Pads, Mille Miglia MM11-2 18x9, Goodyear Eagle F1 GS-D3 245/40-18
