fuel guage - FirebirdV6.com/CamaroV6.com Message Board
fuel guage
  • fuel guage
    i have three questions about this:
    1) is it safe to put it in a gauge pod?
    2) is it possibe to put in a 1997 3.8 firebird?
    3) what extra parts other than the guage do i need?
    ok thanks for the help fellas?
    LiquiD_CooL
    [ October 01, 2002: Message edited by: LiquiDCooL ]
    [ October 01, 2002: Message edited by: LiquiDCooL ]</p>
    1997 3.8 Red Firebird<br />RKSport 2\" racing springs,TA Rims,<br />Dual Out Magna Flow Exaust/2.5\" Exauhst cut-out (loud),<br />2-10\" JL W-3\'s, 300/2 JL AMP<br />1 Farad Rockford Fosgate Capasitor,<br />B&M Shift Improvment Mod,<br />SLP Cold Air Intake, MSD 8.5mm Wires, Bosh Plats, 160 deg thermo<br /> in the mail:<br />Zexel Torsen Posi Unit, 3.23 (for now)& new transmission.
    Fuel pressure gauge?
    I have mine in a 2 gauge pod, along with a vacuum/boost gauge. It is an electrical gauge. The sending unit is mounted to the fuel rail, with a couple of wires that come through the firewall to a box under the dash, then a couple of wires up to the gauge.
    I like it a lot. Mine is a '98 Camaro. I got the gauge from summitracing, it came with everything. Around $180. Electrical are higher than mechanical.
    There was a fuse in the side of the dash for the instrument panel lights, so it was easy to tap into it for the gauge lights, so they operate off the instrument panel dimmer.
    [ October 01, 2002: Message edited by: John_D. ]</p>
      do most fuel psi guages come with the sending unit? if not where do i get one cheap
        <blockquote>quote:</font><hr>Originally posted by LiquiDCooL:
        do most fuel psi guages come with the sending unit? if not where do i get one cheap<hr></blockquote>
        Yes, the gauge should come with the sending unit. The cheapest I found for electrical was $180. Check any of our sponsors, or summitracing.com, or jegs.com.
        Mechanical is cheaper, but you can't mount it inside. Unless you get an isolator. That might be a separately available item.
