How do you test a fuel injector to see if it's working? - FirebirdV6.com/CamaroV6.com Message Board
  • How do you test a fuel injector to see if it's working?
    How do you test a fuel injector to see if it's bad or not?
    1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
    you aren't without specialized equipment, the only way I can think to check would be to get a good one, replace the one you think is bad then see if the car is running better.
    -Brad
    2000 V-Star Custom 1100
    :rock:
      if I remember correctly fuel injectors just require a charge... give them the correct charge and they give you fuel. Don't remember the correct voltage tho magnus probably does.
        If you have a digital multimeter, you can measure ohms across the terminals. You shouldn't get more than a couple ohms (or 12-14 ohms if you have to measure a bank of three). This will let you know if the injector is good electrically, not mechanically.
          I believe a noid light is used to check and see if an injector is bad, but those things are rare and usually only found in auto repair shops. If you need to know mechanically though, not sure. The noid light only checks for electrical.
          1995 Pontiac Firebird
            for mechanically seeing if they're ok, you could bring them to a shop to have them flowchecked. there's a shop here that does them for $5/ea. they charge $25/ea to clean them, just to give you an idea of pricing.
            --matt
            • Manimal
              Coil springs
              by Manimal
              6 days ago
            • Manimal
              Newby here
              by Manimal
