Hey all,
Just thought I'd post this message that might help someone. I've been chasing a missing problem for the last 2 years on my 97 Firebird 3.8 V-6. It started at 36,000 miles, and my car now has 84,000 miles. So far I've replaced the wires 4 times and plugs 5 times along with the fuel injector on cylinder 6, camshaft sensor, PCV valve 2x, fuel filter 3x, all coils, and ignition module. Yup, I've done it all, and that misfire just kept coming back.
Well, just last week I needed to replace my Autolite Racing AR103 plugs with new ones. When I removed the wire for cylinder 6, the spark plug boot was split and burnt quite a bit. You could break the boot apart easily, and these were MSD Superconductor 8.5mm wires mind you. I checked all wires with an ohm meter, and the wires tested like new. The heat from the exhaust, and the proximity of the manifold to the plug boots were ruining the boots though. If this happened to high quality MSD wires (only 30,000k on them), I can see why the stock ones don't last at all. GM replacing the wires was a quick fix, but not the cure for the problem. Read on...
Here's what I did to cure this problem. I replaced all plugs first with new Autolite AR103 racing plugs (very low resistance, but only last 20-25K miles). Then, very carefully I cut off the boots of the wires, since the wires tested fine. MSD sells the boots separately, so I purchased some to replace the ones I cut off. Napa sells some spark plug wire heat sheathing to go over the wires, good for 500 *F constant and 1200 *F radiant heat. With the boots off, I installed this on the wires for cylinders 6, 4, 1, and 3, up to where the wires go into the looms. Wires 2 and 5 were far enough away to not need the wire protectors up to the looms. I then put the new boots on, and installed spark plug boot protectors from Design Engineering Inc. on all 6 spark plug wire boots. These are also good for 500 *F constant and 1200 *F radiant heat. For the looms, I used Made For You's 6-6 nylon wire looms, good for up to only 8mm. However, I drilled them out slightly to fit the 8.5mm wires perfectly.
So far, my car runs better than ever. To me the way the engine is mounted causes the heat to ruin the wires prematurely, causing misfires too easily and possibly ruining the ignition module and coils. In my case, the MSD wire boot in cylinder 6 was fried, causing it to arch and misfire constantly. And these were high quality wires, not the cheap stuff. Up to now, the dealer, my friend who is a mechanic, and another independent shop could never pinpoint the problem. I landed up spending a lot of money replacing things that probably didn't need to be since this problem was never diagnosed properly. GM's replacing the wires was bogus, since they'll eventually go early (and most other sets) due to the extreme heat. I guess that's typical--they took the cheapest way out.
Well, sorry for the long message, but I hope this information will help someone avoid spending a lot of money unnecessary, only to have this problem constantly come back. The boot and wire protectors will keep the heat from ruining the wires/boots and causing that darn misfire.
