for some reason my belt squeels really bad but it only whent he motor is cold does anyone have a solution for this ive tried belt dressing sounds like its coming from the alternator area
belt squeeling but only when its cold?
Re: belt squeeling but only when its cold?
Originally posted by black95marofor some reason my belt squeels really bad but it only whent he motor is cold does anyone have a solution for this ive tried belt dressing sounds like its coming from the alternator area
I personally would replace the belt and the tensioner.
By the way, my past experience tells me that belt dressing spray does not work.
I agree, I would start with the belt because it's cheaper and easier. Since it's noisy it probably needs replacing anyway. If it doesn't help then you have not wasted any money......then you move on to the tensioner. And Nascar is right, belt dressing won't work because it's not supposed to be used on serpentine belts for some reason.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Belt dressing is useless.
1. Pull the belt
2. Spray down all the pulleys with brake cleaner
3. Either clean the grime and grease off your current belt or buy a new one and put it on the new pulleys
If it still squeals, then it's a bearing or something else, but not a slipping belt.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Just replace the belt and you should be good.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
