Placing jackstands - FirebirdV6.com/CamaroV6.com Message Board
Placing jackstands
  • Placing jackstands
    When working with jackstands on the Firebird, where would be the safest place to put them in the front?
    I'm looking under there and don't really see a spot that wouldn't bend/warp something if I set them up. I need to do some work under there and have no ramps since someone stole them a few weeks ago.
    If nobody replies within 20 minutes I guess I will just go buy some more ramps.
    Re: Placing jackstands
    I usually just put them on the frame somewhere.
      http://www.installuniversity.com/ins...sity/index.htm
        I usually go on the frame right behind the front wheels.
        <b>Red 96 3.8 Liter Camaro</b><br />SLP Cold Air Intake<br />Flowmaster Exhaust<br />2 12\" Pioneer Subs in a custom box<br />900 Watt Rockford Fosgate<br />Kenwood Deck<br />new engine at 102k!<br /> <a href=\"http://www.cardomain.com/id/red38fbod96\" target=\"_blank\">http://www.cardomain.com/id/red38fbod96</a>
          I do the frame rails up front... and the rear axle in the rear, unless I am working on the rear axle then on the frame right before the LCAs
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
