PAers! Emmisions law question - FirebirdV6.com/CamaroV6.com Message Board
  • PAers! Emmisions law question
    Ok two parter- 1) With the SLP hi-flow will it throw a code if I dont throw on an oxy simulator?
    2) If it does and I throw on the simulator will I beable to pass the new OBDII emmissions testing now that they are only checking for codes?
    My instinct is that I will be fine but i kinda would like to hear it from someone else- Ian I am thinking this is your set up but I could be wrong...
    By the way I am probably throwin a borla catback on to follow that all up...
    99 3.8 Camaro (M5) Y87
    I don't live in PA and currently there is no emission testing in NYS. But, I added a Catco high flow cat and I did throw a code on a 2001. I then bought an O2 Sim (from Thunderracing) and it cleared the code. I never had the emissions tested to see if it would still pass with the high flow.
    Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
      yeah, you can get rid of the codes with sims. i havent heard, are they eliminating the sniff test and just going to check for codes?
      \'01 Mineral Grey SVT Cobra<br />-former F-body owner
        Yea from now on it is all code tested statewide. Allentown used to be one of the exempt areas it was great but now i gotta watch out for it.
        Thanks for your help all
          so no sniff test, but a single code and you fail? looks like I got a lot of work to do before this fall. :(
            thats the impression that i got
            here are a few links that may help explain
            http://www.dep.state.pa.us/aq_apps/emissions/test.htm
            http://www.dep.state.pa.us/aq_apps/e...s/testinfo.htm
