My exhaust smells like fuel - FirebirdV6.com/CamaroV6.com Message Board
  • My exhaust smells like fuel
    OMG...I can't stand the smell of the exaust fumes. i swear i smell it when i'm driving sometimes...My wife thinks I'm crazy and doesn't smell anything...(she also says she can't smell the cat litter when I can) anyone experience this same problem? how did you remedy?
    1998 V6 Midnight Metallic Purple Firebird<br /><br />The time has come...for everyone to clean up thier own back yard...before they go knockin on thier neighbors door!
    What octane do you use? If you're running rich, you will smell it from the exhaust. I like that smell.
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
      Prolly just a stupid novice question then...This IS my first F-body and i don't know Jack...
        ok i had the same problem today. when im driving my car runs good its when i throw the clutch in it starts hessitating, missfiring, and i can smell fuel in the exhaust. i was wondering will changing the plugs make a difference? or do you think its something more.
          My car runs really rich also. I dunno i burn through gas like a sonofa.. is this bad or not?
          Red 98 A4 Firebird<br />..its pretty..<br />- - - - - - - - - <br />6 Infinity 3-way speakers with Alpine deck and 720 watt Kenwood amp..
            o2 sensors are a good place to start. I think you can take them off and clean them with carb cleaner, then put them back in, and you should start getting better air/fuel mix. Also make sure your air filter isn't really dirty.
            (on the carb cleaner on the o2 sensors, anybody else try this before? I don't want these guys to try it if it will break something)
            2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
              I heard that this can also be caused by bad plugs, wires, or coils because the spark may not be strong enough to burn all the fuel that is being put in your engine or something and that's why it smells. I think that's why mine smells like that. If that's the case you will backfire like crazy too because of the unburnt fuel in your exhaust.
              \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
                hey guys just an update. i figured out what the problem was. well first off the problem happened at night so the next morning i looked under the hood and seen a vaccumm line coming off of the throttle body had come off. anybody know what this vaccumm line does. it goes from the TB to the passenger side valve cover. any ideas?
