Aftermarket Coils: MSD vs. ACCEL - FirebirdV6.com/CamaroV6.com Message Board
  • Aftermarket Coils: MSD vs. ACCEL
    Can anyone offer an opinion on either one? I plan on replacing mine in the near future and am leaning toward the MSD. Someone posted that ACCEL coils are notoriously bad for our cars, can anyone back this up?
    I think the MSD Coils are pretty new, I just saw them in the new Summit catalog. Does anyone have them?
    The p/n is: MSD-8224
    Thanks for the input.
    -Chris
    [ April 30, 2002: Message edited by: 94bird ]</p>
    <b>94 Firebird, 3.4 V6, Red, M5</b><br /> SLP CAI, Accel 8mm Superstock Wires, Bosch Platinum +4 Plugs, Borla Exhaust, BMR Strut Tower Brace, 180* Thermostat, B&M Ripper Shifter<br /> <a href=\"http://www.cardomain.com/id/94bird\" target=\"_blank\">http://www.cardomain.com/id/94bird</a>
    I've been running Accel Coils for about a month. Not a single complaint.
    But I wouldn't run aftermarket coils with the msd dis-4. Thats an expensive mistake.
    http://seppo.hopto.org/
      <blockquote>quote:</font><hr>Originally posted by Seppo Kaitainen:
      <hr></blockquote>
      I'm not planning on getting the MSD DIS-4 box.
      Just want a new set of coils.
      Trying to find out which ones are best.
        But I wouldn't run aftermarket coils with the msd dis-4. Thats an expensive mistake.<hr></blockquote>
        Just curious, why not? Please keep me from making a mistake because I'm waiting on the MSD coils to hit summit, and I already have the box.
        <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
          The guy I bought my coils from blew up 2 or 3 msd dis-4's before he finally when back to the stock coils.
            i have had my accels for almost two years and i have no complaints
            98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
              I have the MSD DIS-4 box with Accel coils and have blown 3 Accel coils already. They worked fine before I put the MSD box on, but now I have blown 3 in the past 4 months. I am planning on switching to the MSD coils ASAP but I am running stock coils right now and they seem fine.
                I know that 96Beastv6 has problems w/ his accels. The motor would miss in the higher RPM's. I'm looking foward to the MSD coils. Now I know not to get a box in the future. I wonder if the MSD coils would work properly w/ the MSD DIS4?
                GM 3800 PowerPak guinea pig<p>\"what cam, that\'s just a nasty mis-fire...\"
                  Correct, I was having problems with my Accell coils. Anytime the engine was under heavy load when it was hot outside (as it ALWAYS is in FL) I would get misfires. It would also misfire even under moderate load at in the upper rpms, like RiceCooker said. I went back to stock coils when I started spraying and haven't had a misfire since. One thing I do notice in this thread though, take a look at the regions that people are at where the Accels are working fine: North Carolina, New York, Delaware, Kentucky. You see the pattern there? All northern areas where there are actually real seasons and it's not hot ALL the time. I think that may be the key to the Accel problems.
                  -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
                    <blockquote>quote:</font><hr>Originally posted by RiceCooker:
                    I wonder if the MSD coils would work properly w/ the MSD DIS4?<hr></blockquote>
                    I've been wondering the same thing. Seems like MSD would make sure the two would work together.
                      Well, they advertise like the two would work together, so I'm gonna go ahead and order them when they're available. I already have the ignition.
                      [ May 01, 2002: Message edited by: AMinor65 ]</p>
                        Thanks for the replies. I'm going to order the MSD's soon. I checked with summit and they are on backorder, if you order them today they say they will ship on 5/15.
                          for those of you with msd dis 4 ignition are there certain plugs that WILL NOT work well with the dis 4 ignition?
                          Email: Preki1212@hotmail.com
                            Does anyone have a picture of the new MSD coils??? i'm dying to see what they look like
                            C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
                              I rarely have problems with my Accel's and it is often 100­­°+ here in Kansas.
