my brother in law is a mechanic and he told me that the older caddies used to have a problem with carbon knock. He said that a mechanic that worked with him once poured water into the intake of a car that my brother in law test drove because it started knocking and that stopped the knocking. Can we do the same to our cars to clean out the carbon and if we can how do u do it.
use water to clean carbon out of engine
I would just stick with Sea Foam. Do a search on it and you'll find a lot of info. ;)Matt
1998 Mystic Teal Camaro M5
yes, water works, ive done it. sea foam is much better though.
either one, pull the vaccum line off the left side of the throttle body, hold the bottle up to the metal tube sticking out, and let it suck the stuff in to the point of just bogging down.
What I do is hook a 1' vacuum line up to the intake fitting, put my thumb over the open end, have someone start the car, and I move my thumb to the side a little bit so it doesn't stall the engine and I pour the seafoam into the vacuum until the engine stalls. (whew! long sentence)
Let the engine sit for about 5 minutes, then I start it up and watch the smoke display. Takes a good 5-10 minutes for the engine to blow all of the smoke out, but it runs much better afterwards.
-Marcsigpic
I've seen/used water on carb motors, never used it on fi cars. Little step-by-step guid for Sea Foam :cool:1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
You may find this interesting: Water Injection2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
