Air/Fuel ratio gauge - FirebirdV6.com/CamaroV6.com Message Board
  • Air/Fuel ratio gauge
    I got an autometer air/fuel gauge and i hooked it up to one of the stock o2 sensors. Is that what im supposed to do or am I supposed install a separate o2 sensor? About half of the leds on the gauge light up at the same time while im driving. Is that normal?
    1995 3.4L Camaro Purple/Yellow<br />Moroso CAI,Jet Stage 2,180 thermostat Flowmaster,Fan switch Mod,Fog Light Mod,Wings West ground effects,RK Sport \"Sport wing\",Yellow racing stripes,Autometer Gauges in pod: Air/Fuel Ratio,Water temp gauge,Voltmeter
    thats what mine does. Its pretty normal...mine goes all the way green when i floor it. which o2 sensor did you tap it into?
    2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
      driver side and it hardly ever goes to the green its mostly in the red section.
        When idle its in the yellow. If i floor it or give it some gas it goes to the red leds.
          ok question, where do u hook it up? i hooked mine up te wires on the Tb and it only goes half way,never in the green, where and what 02 sensor, and what wire did u hook it up to?
          1998 black convertible camaro<br />rasied air box,free ram air , colored inter knobs,b&m shift kit, race magnum muffler, 3 1/2 crome tips, no cat,clear turn signals, custom front grill ,neons
            I hooked it up to the o2 sensor. It only has one wire so thats the one i hooked it up to. I used the drivers side sensor. How come you have it hooked up to the TB. I though you supposed to hook it up to one of the o2 sensors.
              You all might want to switch your connection to the O2 just before the cat. Looking at one side will do nothing if the other starts having a problem. Right now you are only looking at 3 cyl.
              Lightning,
              Why would you hook it up to the TB. You will always get a good reading there. All that does is give you the reading of the air coming in. Disconnect it and connect into the O2 just before the cat after the Y-pipe.
              White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
                The one before the cat is the one "I" have it hooked into. If i can find my sheets i can tell you exactly which wire it is coming out of the computer. Ill start looking for them.
                  Thanks for all your help so far guys. [img]graemlins/love.gif[/img] [img]smile.gif[/img]
                  Jason, I have a 3.4L camaro. Would it be the same for both cars since you have a 3.8? If not where would i be able to find out which wire it is?
                    <blockquote>quote:</font><hr>Originally posted by DragonFlames:
                    <hr></blockquote>
                    3.4's only have 2 O2 sensors. One on each manifold or header. The 3800 series II has 3 O2's. One on each manifold or header and one just before the cat.
                    Steve
                    FirebirdV6.com/CamaroV6.com Administrator
                    Stupid is rewarded with the ban button.
                    Official Avatar Nazi according to Meatyshells :D
                      <hr></blockquote>
                      I'm sorry Dragon I did not see that you had a 3.4. A toggle switch hooked up to both O2's is what a lot of people do. That way you could look at both banks with the flip of a switch. That's what I would do in your situation. Good luck
                        Please dont think im being a jerk or anything but the 3.8 have 4 o2 sensors. One on each manifild , one pre cat and one after cat.
                        Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                          yeah but we have found that the O2 after the cat is usless for our needs....YOU JERK :D j/k
