Torque and engine swap photos - FirebirdV6.com/CamaroV6.com Message Board
  • Torque and engine swap photos
    Well as some of you know I'm swapping motors. Was wondering the torque for:
    1. Flywheel
    2. Oil pan bolts
    3.Upper intake manifold
    4. Clutch plate bolts
    5. Anything else I should know?
    PHOTOS!!
    http://www.photos.yahoo.com/machinefreak@sbcglobal.net/
    Re: Torque and engine swap photos
    1. Flywheel
    2. Oil pan bolts
    PHOTOS!!
    1. 11 lb ft + 50 degrees
    2. 124 lb in
    3. long-22 lb ft short-11 lb ft
    4. 15 lb ft + 45 degress
    2000 3.8 A4 Pewter Camaro
      must be nice to be an ASE GM Tech huh?
        2. 124 lb in
        Thanks A LOT, really appreciate it :D
          2. 124 lb in
          1- 11 lb on the flywheel? that's barely past snug
          2- 124 lb on the OIL PAN BOLTS?!?! I broke a bolt off trying to torque one down
          3- Hoping this is right???
          4- once again, just snug
          were you on drugs when you made this list? lol 11lb on the flywheel and 124lb on the oil pan??!!?
            thats 124 inch pounds, not foot pounds. read what i typed and yes I'm sure. i double checked
              ok got the oil pan but 11 FT LBS on the flywheel? I snugged them up and was already in the 20's
                doing the 50 degrees adds more torque... but yes, 11 is the GM Spec + the 50 degrees
                  there are not much force on the flywheel to pull it out. the torque converter is attached to it but thats all held in by the tranny being bolted to the engine.
                    I got these out of my repair book for the 1993-02 Camaro/Firebird these pics are for the 3800 motor.
