mileage will not show now on gauge - FirebirdV6.com/CamaroV6.com Message Board
  • mileage will not show now on gauge
    I recently got a remote start installed on my car and now I noticed that my mileage dosen't show. The car starts up fine without a problem the mileage just isn't showing and Its almost time for me to get my car inspected so I need help bad.
    Does anyone know what could be causing this problem I checked the fuses inside the car but I didn't check the fuses under the hood please help
    Re: mileage will not show now on gauge
    digital?
    Where is the remote start hooked into? cluster needs to be replaced.
    2000 3.8 A4 Pewter Camaro
      and how much will this cost me. When I turn the key I can see my mileage light up to like 93,000 then it dosen't show anymore I might have to unplug my battery and see what happens.
      I believe the remote start is hooked up under the drivers side dash. This would happen when its time for inspection
        dam I am dumb as hell the only problem was the switch that dims the lights was turned all the way down there was nothing wrong what a relief
          lol....I have done that at work. was inspecting a brand new Tahoe, started noticing none of the door switch lights were working then noticed the cluster seemed inop too. I about flipped until I realized what was going on shortly after. :p
            how can I turn mine back? I would like to do some illegal operations on the odometer to sell my car for less miles then it actually has.
              Is this guy serious?!:eek:
                Not quite sure if this works on the fbodies, I've never tried it. But, I used to have a Ford Ranger and the fuse that went to the windshield wipers also powered the odometer and the "dinger" that went off when a door was open. Well, my "dinger" would always stay on, no matter if the door was opened or closed so I removed the fuse. It took a week for me to notice the odometer wasn't moving anymore.
