Alright I did a search and did not find a specific answer so I thought I would make a new thread. Lately my car was having some trouble starting and now will not start at all. The battery is fine, I've checked that. It does not make any attempt to start, no clicking, nothing. I and some others have come to the thought that the starter might be the problem. I was wondering if anyone knew how difficult this was to replace and if anyone knew any other problem areas I should check. The problem car is a 1996 Firebird v6. Thanks again guys. -Nick
Starter
Re: Starter
Unlike most work on a F-body, the starter is actually fairly easy. FIRST OFF, REMOVE THE POSITIVE BATTERY CABLE. Jack up the car and look behind the bell housing and you will see the starter, it is on the drivers side of the car parallel (horizontally)to the motor. there are 2 long bolts I believe holding it in. Unbolt those two and get your battery cables unscrewed. Buy a new starter or I would get a salvage starter and reinstall in reverse order. Best of luck to ya!
Re: Starter
are you sure its not a security issue? is your security light flashing
Re: Starter
No the light does not flash. Just in case it is out I will try the spare key that usually works. Everything will turn on also just no attempt at starting.- Why tiptoe through life to arrive safely at death -
Re: Starter
is it a 5-speed? if so check the neutral clutch safety switch.
if its an auto, check the Park/neutral safety switch
then the vats. Usually when the starter craps, it clicks or makes noises. Mine crapped on me, and made whirring noises. Easy swap.
Re: Starter
sorry to highjack this thread but when you say a whirring sound is it that sound when you turn the key to the on position then turn it the second position and it just clicks a punch of times and eventually starts? the reason i am asking is i am having trouble starting my car but i dunno if its fuel or ignition .2000 firebird w68, auto, t-tops , 3.42 , k&n, whisper lid, taylor 8mm spark plug wires , bosch spark plugs , 3\"in/out carsound CAT , 3\" i pipe, take off trans am muffler, C6 Z06 rims
Re: Starter
How do i check the park/neutral safety switch ..it is an auto Alright here is an update..kind of odd. I was going to the store to buy a manual since I can't seem to find mine when I thought eh what the heck I'll give it a try. Well it started up and now I have no clue as to what the problem was/is. Any ideas?Last edited by 96_Fbird; 12-20-2006, 12:55 PM.- Why tiptoe through life to arrive safely at death -
Re: Starter
mine just did this and i just got it fixed two days ago. i was on the way to my girlfriends, and i stopped by the gas station to get an ice cold coke, when i went to start my car it wasnt doing anything at all(no clicking, ect) everything would work in the car, my subs, lights, radio, and even my headlights. long story short.....we thought it was the starter. it wasnt. we put power to it and it worked fine. it is the ignition switch. the little chip that is on your key has to be reprogrammed along with a new ignition switch from the factory(yes it is a dealer item only)Last edited by 1999Spectre; 12-20-2006, 04:21 PM.
Re: Starter
The spare does work the only problem...I can't tell if it is that because my key is back at school...3 1/2 hours away but hopefully my roommate will be bringing around christmas. I didn't have any luck getting the starter off so I am going to try and get it in the shop sometime soon. Also I believe once before the spare key did not work, but worked today ...so not sure if I want to rely on that. Anyone ever replace a starter. When I tried it was easy to find, but much more than 2 bolts, well to get to the 2 bolts it was.Last edited by 96_Fbird; 12-20-2006, 04:50 PM.- Why tiptoe through life to arrive safely at death -
Re: Starter
put power to the starter. if the engine cranks then that is not your problem. there is prolly a short in a wire between the starter and the ignition switch if you are having a major problem. but if your other key works i dont think i would worry too much about it. go to autozone and have them scan it, cause it will through a code more than likely.
