When I turn on my Rear defroster in my 2000 camaro it turns it self off in about 5 minutes then I cant turn it back on for about another 10 minutes, What could be causing this?
Rear Defroster
Re: Rear Defroster
no its not dude. i can turn mine on, it'll run for like 5 or 10 mins and turn off by itself and i can turn right back on for 5-10 minutes. I'm almost positive its working the way its supposed to cuz EVERYTHING worked on my car when i got it some 50000 miles ago and thats what it did back then.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Re: Rear Defroster
Hey, feel special at the least. My 97 doesn't even have a rear defroster. :(
I don't see what the big deal about it is though, I hardly ever use my rear view mirror to look behing me. Side mirrors are all that's needed for backing up, and if you are trying to change lanes, just speed up a lot and then if nothing is seen in the side mirror it's safe to get over.
The rear defroster is made to stay on for less time with each use of a consecutive time, because too much heat to a cold piece of glass can cause it to crack. Have you ever thrown water on your windshield in the morning when it's frosted/iced up and heard something crack? It's not good to put too much heat on anything that's frozen.
Re: Rear Defroster
At least you can get your rear defrost to work. When I press the button no light comes on and nothing happens on the rear window. I've replaced the amp with a new amp and then again with a fuse. It's still a no go.
Re: Rear Defroster
Originally posted by VanquishHave you ever thrown water on your windshield in the morning when it's frosted/iced up and heard something crack? It's not good to put too much heat on anything that's frozen.
