I have a 96 3.8, when i am idling or give it a little gas there is a rattle. I crawled under there to see where it was coming from. Its coming from around flywheel/clutch area. I know its not my cat. It doesnt matter if my clutch is engaged or i have it in gear. Somewhere i read on here that the spring governing the pinion gear could be hitting the flywheel?? i did notice that there is a mark on all the teeth on the flywheel. think this could be it???
Rattle is getting worse...
Re: Rattle is getting worse...
are you sure its not a heat shield? the one around the cat is close to the clutch/flywheel area. just trying to eleminate the easy stuff. ive never read anything about the pinon problem but it seems possible.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by loserare you sure its not a heat shield? the one around the cat is close to the clutch/flywheel area.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGTThe Cat heat shield rattles on my 96.
any updates on the car? check the whole exhuast system and heat sheilds. does it rattle over bumps/pot holes? is it constant or hit and miss?1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by iGoRaIt did on mine too , and there is another one down the pipe.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
I checked the heat shield on the cat. The rattle is definately coming fromthe engine area. It rattles at low RPMs. I have looked for hours trying to find some sort of shield loose. Could it be something in the lower end of the engine? or would that rattle all the time instead of just low RPMs. I plan on doing the clutch in a couple weeks so i guess i will just park her untill then:mad:
Originally posted by loserseems to be a common problem, it rattled on mine too. i just ripped it off.
Originally posted by benavidez19I bet its the muffler hitting that support thing right under the DS. I think its called tubular somthing. I took mine off and problem solved.
Remove your heat shield from your cat and drive around for a short while or just sit there and keep it revved in low rpms and see if anything happens.
A sound clip would be a great thing for us to have if you have the capability of getting us one.
