Start-up problem - FirebirdV6.com/CamaroV6.com Message Board
Start-up problem
  • Start-up problem
    I have a 98 camaro w/ 79820 miles on it. Everytime i go to start my car after its been sitting for a while, the engine turns over and all of a sudden the rpm gauge revs up and down and the lights dim on and off for a few seconds. Car shakes a little and after about a minute of warm up, the car runs and acts normal?? What could be causing the problem?? Tune-up? Alt? Battery?? Thanks in advance guys!!
    Re: Start-up problem
    With so little of information on each problem, I would say all of the above and a vaccuum leak.
    The rpm's at startup are normal, if it's just going up once, and then coming down. If it's going up and down numerous times, it sounds like a vaccuum leak. Then, the shaking could be anything from your engine trying to die because it needs a tune-up or it was barely powered and is trying to make up for the less power that was delivered to it by a dying battery.
    When is the last time you had a tune up on your car and do you have anything that drains your batteries life? Like a sound system or a radar detector that stays on all the time, or charge your cell phone in the car when it's not turned on. Or just leave the car sit for a week at a time sometimes? Any of those can do it over time.
      Sounds very similar to what mine is doing. I'm thinking that I have a leaky injector.
