starting Woooes - FirebirdV6.com/CamaroV6.com Message Board
starting Woooes
  • starting Woooes
    Ok so everyone else is posting starting issues so I thought I would jump on the boat. this started about a month ago and has been bugging me ever since. here goes.
    first I am driving a 1996 camaro with a auto trans.
    most of the time it starts right up not even 4 or 5 revolutions and it fires, BUT if I miss the first fire for somereason (I.E. just not paying attention, let go to soon, ETC.) the car will not start for roughly 20 to 30 min no matter what I do. I have tried everything I can think of on this. checked wires and plugs, reset the PCM, checked for fuel at the rail I am out of ideas on this one. anyone have any sugestions on this I am begining to think I might have a pcm problem.
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
    Re: starting Woooes
    sounds like a fuel or spark issue, what happens when you try it during the 20-30 min period? cranks but wont turn over?
      Re: starting Woooes
      yes it just cranks but if I let it sit for like 25-30 min it will start like normal.
        Re: starting Woooes
        hmm, yea i dont think its a pcm problem, but i wouldnt know what it is specifically, hopefully someones else can be of more help.
          Re: starting Woooes
          If it was carb'd I'd say possible vapor lock. But I don't recall FI cars getting vapor lock too much. I've heard crazy things happen though.
          have you tried the Ignition Control Module?
            Re: starting Woooes
            no I have not checked the ICM but that is a thought. I am also going to look into things like the ignition key. Does anyone know what the result of a key that has a bad chip in it might be?
              Re: starting Woooes
              theft light should blink while it's cranking.
                Re: starting Woooes
                possibly bad coils??
                  Re: starting Woooes
                  well the drama continues the car totaly failed to start tonight and is currently sitting in the walmart parking lot it just would not start. I thought thatit might be a warm start problem but I am stumped on this. I am going to try to get it home in the morning and hook it up to the laptop and see if there are any codes.
                    Re: starting Woooes
                    First thing I would do is to check for spark only when that problem occurs and also if the Fuel pump motors when the ignition is switched on.
                      Re: starting Woooes
                      Well I FINALLY hooked up my auto tap to the thing and found that my crank position sensor is what is causing the problem. What I am a little bit upset aboutis this code gets set in the computer but it DOES NOT turn on the service engine soon light. I find that a little odd. but at least I know what it is and it is only a $30 part. the bad thing is that I have to pull the harmonic ballencer off to get to it. OH WELL. guess it is back up on the ramps for the green machine. I also wanted to say thanks to all of those that helped me with this.
                      • 187shark
                        by 187shark
