hey im taking the valve covers off my 3.4 and on one step in the instructions it says to bleed the fuel pressure. does anyone know how to do this?
fuel rail assembly
Re: fuel rail assembly
there is a (schreder ???) valve.
it looks and operates much the same way a stem on a tire does. You will unscrew the cap and press down on the center with a screw driver. Makes sure to try and cover it with a towel as fuel will spray
or you can take the fuel pump fuse out and crank it a couple times. This will relieve pressure and use gas in the lines. Another way is to unscrew gas tank cap or use the schrader valve
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...5 days ago
