Whats the rocker nut torque spec? - FirebirdV6.com/CamaroV6.com Message Board
  • Whats the rocker nut torque spec?
    Whats the rocker nut torque spec? did a search but couldnt find it....and it doesnt matter what location the piston is right? just add assembly lube and torque to spec?
    Re: Whats the rocker nut torque spec?
    piston location doesnt matter...I wsh I could remember the specs off hand, but I cant... we need to have a sticky of torque specs!
      what year and engine?
      2000 3.8 A4 Pewter Camaro
        95 camaro 3.4
          I take it nobody knows.
            went ahead and used valve lash since i have both books and kind find anything about just torque to spec....
            i turn the balancer with a breaker bar till i saw piston 1 rockers move(passenger side front) then i turned one complete turn and that should bring me to piston 1 tdc....right?
            second thing since my motor looks a lil different then the ones on both book i have(haynes/dealership book) can some one describe to me what the exhaust/intake valve looks like....
            i have a oil shield like cover i one spring and the other is just the spring....i assumed the one with the cover was the intake valve...
            i know i did something wrong becuse when i started to adjust the piston 2 exhaust (i think) it seems there was hardly any play as if the valve was open...so where am i getting confused.
              never mind i got it.
                6 days ago
