Whats the rocker nut torque spec? did a search but couldnt find it....and it doesnt matter what location the piston is right? just add assembly lube and torque to spec?
Re: Whats the rocker nut torque spec?
went ahead and used valve lash since i have both books and kind find anything about just torque to spec....
i turn the balancer with a breaker bar till i saw piston 1 rockers move(passenger side front) then i turned one complete turn and that should bring me to piston 1 tdc....right?
second thing since my motor looks a lil different then the ones on both book i have(haynes/dealership book) can some one describe to me what the exhaust/intake valve looks like....
i have a oil shield like cover i one spring and the other is just the spring....i assumed the one with the cover was the intake valve...
i know i did something wrong becuse when i started to adjust the piston 2 exhaust (i think) it seems there was hardly any play as if the valve was open...so where am i getting confused.
