MAIN Ignition Wire.....where is it??! - FirebirdV6.com/CamaroV6.com Message Board
  • MAIN Ignition Wire.....where is it??!
    I need the wire that controls the whole ignition so that when I hook up a turbo timer that the fuel pump, computer, ect stays on when the key is out/off.
    What the timer does is interfers with the ignition signal fooling it in thinking the key is still in and on when I really take it out.
    Im thinking its one of the wires under the steering column. Please only reply if you are 100% what one it is....I dont wanna be cutting wires that could cause damage. Thanks.
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    The one that goes from the column to the vats/relay/pcm thing? I might know, gotta find my wiring notes..............
    2013 Ram 1500 Big Horn
    94 comero 3.4
      OK but remember I have a 3.8.
      Past Ride
      Current Ride
        OK, remember, I'm putting in a 95 3.8 [img]graemlins/stickpoke.gif[/img] ;)
        [ December 22, 2003: Message edited by: 3.4 slow to go ]</p>
        94 comero 3.4
          dont gimme lip boy! :D
          Past Ride
          Current Ride
