another damn problem :( - FirebirdV6.com/CamaroV6.com Message Board
  • another damn problem :(
    tried to go somewhere today and the damn thing wont start checked the battery and its ok when u turn the key on it dont make any type of sound evrything comes on like any normal time but when u try to start it u hear nothing what could be wrong with my car? 3.8 a4 96 firebird so u know.
    Re: another damn problem :(
    are the clamps tight on the battery terminals? (make sure there's no corosion either)
    bad starter?
    1999 Camaro Z/28
    1973 Firebird Formula
      Try disconnecting the battery, and put another battery in it's place.
      I had a bad "Cell" once in my battery. It tested okay, but wouldn't do anything when I turned the key. Ended up replacing the starter and all of the battery cables before I found out that it was just the battery ~alone~ that was bad :mad:
        but evrything was working and even put a charger on it and tried to start it with it on there and the battery was at 13v's and still did the same thing and it dont make any noises or anything no click no nothing
          was your secrity light on ever how y spell it do y have a vats key
          96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
            When I had the bad battery, I had a towtruck attempt to jump my car over and it still didn't work. IF I would have just disconnected the battery, it would have started right up when the towtruck had the jumpers hooked up. The battery was sending a bad connection to the starter and nothing would have kicked it over as long as the cables were hooked up to it.
            It's just a guess though...
              it was blinking but i thought it always did that so i wasnt sure but there were times that it just stayed on and never blink and do the same thing but this time its blinking whats that mean?
                sounds like a vats problem there a web site that tells y how to bypass the vats one trip tp radio shack and that will be gone i ll look for the site and get back to ypou soon
                  whats vats?
                    do y have a chip in your key at the middle of it after the cut part of the key itself
                      yes it does
                        thats a vats heres a site that will help you rid that read 21/22/23
                        http://shbox.com/1/how_tos.html
                          where do i get a bypass resistor?
                            you have to get a ohms meter seewhat the resistins is there and go to radio shack they sell them
                              im pretty sure that u have chip in ur key right? cuz my 96 does...try a spare key...i had a problem with my security light comin on and blinkin at me...same problem that u had my car wouldnt start until the light went off....so i used my spare key 1 day cuz i couldnt find my keys in my room and the light has stayed off now for a good 2 months
                              87 Firebird RIP
                              96 Camaro RS RIP
                              94 Patriot Red 1LE Z28 - Sold
                              02 WS6 TA - Sold
                              • 187shark
                                by 187shark
