tried to go somewhere today and the damn thing wont start checked the battery and its ok when u turn the key on it dont make any type of sound evrything comes on like any normal time but when u try to start it u hear nothing what could be wrong with my car? 3.8 a4 96 firebird so u know.
another damn problem :(
Re: another damn problem :(
Try disconnecting the battery, and put another battery in it's place.
I had a bad "Cell" once in my battery. It tested okay, but wouldn't do anything when I turned the key. Ended up replacing the starter and all of the battery cables before I found out that it was just the battery ~alone~ that was bad :mad:sigpic
was your secrity light on ever how y spell it do y have a vats key96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
When I had the bad battery, I had a towtruck attempt to jump my car over and it still didn't work. IF I would have just disconnected the battery, it would have started right up when the towtruck had the jumpers hooked up. The battery was sending a bad connection to the starter and nothing would have kicked it over as long as the cables were hooked up to it.
It's just a guess though...sigpic
Originally posted by APRILS Zwas your secrity light on ever how y spell it do y have a vats key
sounds like a vats problem there a web site that tells y how to bypass the vats one trip tp radio shack and that will be gone i ll look for the site and get back to ypou soon96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
do y have a chip in your key at the middle of it after the cut part of the key itself96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
thats a vats heres a site that will help you rid that read 21/22/23
http://shbox.com/1/how_tos.html96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
you have to get a ohms meter seewhat the resistins is there and go to radio shack they sell them96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
im pretty sure that u have chip in ur key right? cuz my 96 does...try a spare key...i had a problem with my security light comin on and blinkin at me...same problem that u had my car wouldnt start until the light went off....so i used my spare key 1 day cuz i couldnt find my keys in my room and the light has stayed off now for a good 2 months
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
