1996-1997 O2 sensor help..need some pics - FirebirdV6.com/CamaroV6.com Message Board
  • 1996-1997 O2 sensor help..need some pics
    Here is my issue, my new engine is a 96 3.8L...has absolutely everything except the catalytic converter 02 sensors and the wiring part they attach to. The only part on the wiring harness that we think might go to the rear sensors has an empty plug.
    If someone could take some pics of 02 sensor placement and where they plug up to wiring harness I would be very very appreciative. I need to know what the connectors look like so I can get the parts to do my install.
    I am gonna put sims in place of the original 02 sensors, but i need to know what the sensors hook up to. Thanks ahead!
    2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
    If you still need them I will be under my car this weekend and can take some pics for you. Sorry I can't do it any sooner, it's almost christmas!!! Busy busy busy
      any help is appreciated!
      [ December 24, 2003: Message edited by: speedracer95v6 ]</p>
        Anyone know what i'm talking about? The connector that runs from the main wiring harness to the rear o2 sensors at the catalytic converter.
        I need a pic of one or the actual part! If someone can take some pics it would help a whole lot! just need to know what that part looks like
          They did switch from 4 total O2 sensors to 3. I don't remember what year but it is possible that it was 95-96. If thats the case the post cat sensor is the only one you have and you only need one sim. BTW....no need to do more than 1 sim....even if you have the post and pre cat sensors.
            Nope, my '95 has 4.
            95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
              The problem I have begins here:
              I have a 95 with the 3.4L.
              I am putting a 96 3.8L in.
              I have all accessories, computer, wiring harness, and front o2 sensors(on exhaust manifolds) except the rear o2 sensors and their wiring stuff didn't come with the engine.
              There are no cut wires on the wiring harness I have, so I have been led to the conclusion they connect to one empty connector. I just do not know what the wiring from the connector looks like or how many o2 sensors.
                Anyone?
                Can i run the engine with no trouble(short of an SES light) without the catalytic converter sensors? If thats the case, i'm all for removing that cursed bulb.
                [ January 01, 2004: Message edited by: speedracer95v6 ]</p>
                  I don't have pictures. I have one O2 just before the cat, and another one right after the cat.
                  1996 3.8 Firebird with some mods
