belt stops - FirebirdV6.com/CamaroV6.com Message Board
belt stops
  • belt stops
    NOT MY CAR
    when we turn the car on it's ok. but when you turn on the defrost the serpt. belt stops all together and of course the battery starts to drain very fast. Think that this is just the altenator? cause when you turn off the deforst it's ok.
    WAWA-A-HOLIC
    Re: belt stops
    the entire belt stops spinning? If the alt went, I dont see why the pulley wouldn't keep spinning, it just wouldn't be producing any more power.
    Are all the other pulleys moving? Crank, WP, etc...Considering the crank pulley is what drives the belt, this sounds weird. Maybe I'm reading it wrong
      Re: belt stops
      Originally posted by kristen
      NOT MY CAR
      Well if the belt stops then obviously the battery is gonna drain because the altenator isnt moving
      and when you say you "turn of the defrost its ok" whats ok everything? does the battery still drain? If everything is fine until you turn the defrost on i dont think its your alternator. Its prob in your heating and cooling system
      what happens if you put on the air conditioner?
      EDIT: Blown beat me to this post but yea it sounds like one of the belts is stopping when you turn on the heat
        Re: belt stops
        yea, that must be a hell of a problem, are all the other pulleys still spinning but the belt not moving?
          Re: belt stops
          Whenever the belt stops, is there a grinding noise, or a noise that indicates it wants to continue spinning?
          For troubleshooting purposes only, go purchase a smaller belt and skip over the pulley and see if it stops whenever you turn your heater on. You can always return the belt.
            Re: belt stops
            it seems like one pulleys is not moving and its probably the heater
              Re: belt stops
              Kristen, we need answers to help.
                Re: belt stops
                I would say your air compressor is locked up. It turns on when you turn on you defrost no matter whether you are on air or heat. It is drying the air before you heat it.
                2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
                  Re: belt stops
                  exactly
                    Re: belt stops
                    yep, turn the AC onto max, it'll probly do the same thing
                    Custom interior...
                    TEAM NoVa
                      Re: belt stops
                      Maybe a new serp belt is in order?
                      1999 Camaro V6 3.8L A4<br />Red, T-tops, Monsoon<br />No mods.......yet.
                        Re: belt stops
                        Yep thats it. Only its not an air compressor its a refrigeration compressor. My guess is the A/C had a leak and didnt work. All the freon/oil leaked out of it and it locked up so when the pully clutch ingages it stops spinning and stops the belt. You can unplug the power to the compressor at the plug right on the compressor. It will not stop the belt useing defrost if it is unplugged.
                          Re: belt stops
                          she stopped posting....i dont think its an issue anymore.
                            Re: belt stops
                            Well i would like to know what it was. =)
                              Re: belt stops
                              yep...
                              only thing it could be, if its realted to AC controls and the pulley stopping.
                              I know **** about fixing the compressor but sounds like what it is.
                              BTW I bet is smells great.... LOL burning belt.
