PO128 Help - FirebirdV6.com/CamaroV6.com Message Board
PO128 Help
  • PO128 Help
    its coolant temperature is below thermostat operation temp... what the **** does this mean..i had it flushed...and its still throwin the code..do i need a new thermostat or is it cause the sensor is shady..someone help
    Re: PO128 Help
    Does that mean your car is heating up enough for the Thermostat to open? I hope that's not what it means, because I find that really hard to believe.
    But, in any case, take out your thermostat and make sure that it is nice and clean and nothing is clogging it up or anything.
      Re: PO128 Help
      what does your temp gauge say when you are at operating temp
        Re: PO128 Help
        the gauge has been takin a fit not to work....idk if its electric or what..but thats in the works and when it does work its reading a lil colder but i had it flushed and cleaned last week...and nothing changed.. i just don't what the code means is screwed up and was hoping someone could help me..lol if they have coil packs and a thermostat at advance tomorrow im going switch it all anyway
          Re: PO128 Help
          replace your thermo.
          2000 3.8 A4 Pewter Camaro
            Re: PO128 Help
            lol I aint had time to check it but its running normal temp...the sensor is kinda loose though ..its loosin signal every once in awhile and im thinkin that may be it... but i've not had time to change the thermostat..had to replace the hood since a deer got me last march..and put the coil packs on
