My fiance has 3.4L Camaro. Oil leaking pretty bad. I got under the hood just now and I can see Oil at the very back by the firewall on top. So would this possibly be valve cover gaskets?
3.4 Oil Leaking (BLLDGG)
30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>Tags: None
Re: 3.4 Oil Leaking (BLLDGG)
would that throw a code? there is no SES light. How would I go about checking that?
**edit** nevermind search is my friendLast edited by 1SL1k30thCam; 01-02-2007, 07:51 PM.30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
There's an O-ring seal in the back of the lower intake manifold on the passenger side for the oil pump drive that is prone to leaking on the 3.41994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by FunkZThere's an O-ring seal in the back of the lower intake manifold on the passenger side for the oil pump drive that is prone to leaking on the 3.4
Originally posted by 99pewterv6When i had my 3.4l camaro I had a bad oil leak and it turned out that it was just the oil pressure sending unit. You might check that.Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
