Jacking points? - FirebirdV6.com/CamaroV6.com Message Board
Jacking points?
  • Jacking points?
    I only jacked my car up once since i've owned it to change the oil and that time is due. There was no picture in my Haynes manual so yeah... Something like this would be sweet
    That is a Fiero btw. Thanks in advance
    ~josh~
    Re: Jacking points?
    when i put mine up on the hoist i use the waffle type pads under the car behind the front wheels, and the rear suspention bars.
      Re: Jacking points?
      i have ramps makes life easier
        Re: Jacking points?
        are you jacking up the entire car, or just the front?
        I'm guessing just the front if you are changing the oil. And roll the jack underneath your car at the front and raise it at the k-member. If your jack isn't a low profile floor jack you may need to put two boards underneath your front tires, something that is 2 inches or thicker would be best.
        Then, you can put your jackstands on the k-member if you want or you might be lucky like me and have a black guard behind each of your front tires that is used for jackstands/raising purposes.
          Re: Jacking points?
          I would not jack from the k-member. girl friends dad dropped my car jacking from there. I only jack from the frame, rear axel and where some suspension part hooks into the frame in the rear which looks like a leaf spring mount :\
          I have never looked at what the suspension part is....lol
          2000 3.8 A4 Pewter Camaro
            Re: Jacking points?
            So does no one have a black and white or simliar picture like the above Fiero example?
              Re: Jacking points?
              a manual does plus a lot of other stuff :)
                Re: Jacking points?
                just buy ramps they arent expensive and a sh*tload easier then jacks and u dont have to worry about the car falling on u
                  Re: Jacking points?
                  lol, you dont have to worry about it falling or rolling if you use jackstands... lol
                    Re: Jacking points?
                    yea but ramps are still easier
                      Re: Jacking points?
                      Those are NOT jacking points!!
                      Raven
                        Re: Jacking points?
                        What exactly are they, because I have always wondered. I've used them before to jack up the car and used them as jackstands. In fact, my car has been sitting on jackstands since late November/early December in that exact spot.
                          Re: Jacking points?
                          Did you not ever see the "Do Not Jack Here" next to it? My manual shows to lift only on the sub-frame. Dealer also told me this years ago. Your fuel lines run underneath. The 98+ do not have it as the fuel lines were rerouted. Can damage the front fender mount. Car is not balanced front to rear.
                          Should I go on?
                          Raven
                            Re: Jacking points?
                            the only time you should use the pinch weld is for the emergency jack in the back of the car. it has the indentation for the pinch weld.
                              Re: Jacking points?
                              Should be the same for us v6ers:
                              http://www.installuniversity.com/ins...ift_points.htm
                              Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
                                6 days ago
