Torque Specifications
* = degrees
General
• Spark Plugs
(3800)144 in-lbs
(3.4L)23 Ft-lbs
• Engine Oil Drain Plug
(3800)15 to 20 Ft-lbs
(3.4L)15 to 20 Ft-lbs
• Automatic Transmission Pan Bolts
(3800)96 to 120 in-lbs
(3.4L)96 to 120 in-lbs
• Wheel Lug Nuts
(3800)100 Ft-lbs
(3.4L)100 Ft-lbs
Engine Specific
3800 Engine
• Camshaft Position Sensor Studs
22 Ft-lbs
• Camshaft Sprocket Bolt
74 ft-lbs + Turn an additional 90*
• Camshaft Thrust Plate Screws
132 in-lbs
• Crankshaft Balancer to Crankshaft Bolt
1998 and Earlier
111 Ft-lbs + Turn an additional 76*
1999 and Later
111 Ft-lbs + Turn an additional 114*
• Crankshaft Sensor Bolts
18 Ft-lbs
• Camshaft Sensor Bolts
Through 1999
48 in-lbs
2000 and Later
96 in-lbs
• Flywheel/Driveplate to Crankshaft Bolts
132 in-lbs + Turn an additional 50*
• Exhaust Manifold to Cylinder Head Bolts/Studs
1998 and Earlier
106 in-lbs
1999 and Later
Stud/Nuts (Front Two) - 132 in-lbs
• Intake Manifold Fasteners
1999 and Earlier
132 in-lbs
2000 and Later
Lower Manifold to Head
132 in-lbs
Upper Intake Vertical Bolts
132 in-lbs
Water Outlet Bolts
20 Ft-lbs
Side Bolts
22 Ft-lbs
• Oil Filter Adapter to Timing Chain Cover Bolts
1997 and Earlier
22 Ft-lbs
1998 through 2001
2002
22 Ft-lbs
• Oil Pan Bolts
125 in-lbs
• Oil Pump
Cover to Timing Chain Cover Bolts
98 in-lbs
Pick Up Tube and Screen Assembly Bolts
132 in-lbs
• Valve Cover Bolts
89 in-lbs
• Rocker Arm Pivot Bolts
132 in-lbs + Turn an additional 90*
• Valve Lifter Guide Bolts
22 Ft-lbs
• Main Bearing Cap Side Bolts
132 in-lbs + Rotate an additional 45*
• Connecting Rod Bolts
20 Ft-lbs + Rotate an additional 50*
• Balance Shaft Gear Bolt
16 Ft-lbs + Rotate an additional 70*
• Balance Shaft Retainer Bolts
22 Ft-lbs
3.4L Engine
• Air Intake Plenum Bolts
216 in-lbs
• Crankshaft Balancer Bolt
58 Ft-lbs
• Crankshaft Pulley Bolts
37 Ft-lbs
96 in-lbs
96 in-lbs
• Cylinder Head Bolts
41 Ft-lbs + Rotate an additional 90*
216 in-lbs
61 Ft-lbs
• Intake Manifold to Cylinder Head Bolts/Nuts
22 Ft-lbs
• Oil Pan Bolts/Nuts
Front Corner - 24 Ft-lbs
Rear Corner - 18 Ft-lbs
Side Bolts - 89 in-lbs
Studs - 53 in-lbs
• Oil Pump Mounting Bolt
30 Ft-lbs
• Timing Chain Cover Bolts
Small Bolts - 180 in-lbs
Large Bolts - 35 Ft-lbs
• Timing Chain Sprocket to Camshaft Bolt(s)
216 in-lbs
• Valve Cover Nuts
89 in-lbs
• Main Bearing Cap Bolts
37 Ft-lbs + Rotate an additional 77*
• Connecting Rod Cap Nuts
37 Ft-lbs
Cooling / Heating / AC
• Thermostat Housing Bolts
(3800)21 Ft-lbs
(3.4L)21 Ft-lbs
• Water Pump Attaching Bolts
(3800)132 in-lbs + Rotate an additional 80*
(3.4L) Long Bolts
33 Ft-lbs
Short Bolts
192 in-lbs
Small Bolts
89 in-lbs
• Water Pump Pulley Bolts
(3800)115 in-lbs
(3.4L)216 in-lbs
Fuel and Exhaust
• Exhaust Pipe to Manifold Nuts
(3800)15 to 22 Ft-lbs
(3.4L)15 to 22 Ft-lbs
• Air Intake Plenum Mounting Bolts/Nuts
(3800)
(3.4L)18 Ft-lbs
• Fuel Rail Bolts/Nuts
(3800)75 to 84 in-lbs
(3.4L)18 Ft-lbs
• Throttle Body Bolt/Nuts
(3800)84 to 89 in-lbs
(3.4L)20 Ft-lbs
• IAC Valve Screws
(3800)27 in-lbs
(3.4L)30 in-lbs
Manual Transmission(5 Speed)
• Back Up Light Switch
28 Ft-lbs
• Reverse Lockout Housing Hold Down Screw
156 in-lbs
• Skip Shift Solenoid
30 Ft-lbs
• Transmission to Bellhousing Bolts
55 Ft-lbs
• Transmission to Engine Bolts
70 Ft-lbs
• Torque Converter to Driveplate Bolts
46 Ft-lbs
Clutch
• Pressure Plate to Flywheel Bolts
Through 1999
15 Ft-lbs + Turn an additional 30*
2000 and Later
15 Ft-lbs + Turn an additional 45*
• Release Cylinder Retaining Bolts/ Nuts
1997 and Earlier
All Except 3800 V6
15 Ft-lbs
3800 V6
71 in-lbs
1998 and Later
71 in-lbs
• Master Cylinder Retaining Nuts
20 Ft-lbs
Driveshaft
• U-Joint Strap Bolts
14 Ft-lbs
• Center Support Bearing Bolts
Through 1999
50 Ft-lbs
2000 and Later
37 Ft-lbs
Rear Axle
• Pinion Shaft Lock Bolt
Through 1999
96 in-lbs
2000 and Later
27 Ft-lbs
Brakes
• Brake Booster Retaining Nuts
15 Ft-lbs
• Caliper Bleeder Valve
Front
106 to 115 in-lbs
Back
97 in-lbs
• Caliper Mounting Bolts
Front Caliper Guide Pins
1997 and Earlier
38 Ft-lbs
1998 and Later
23 Ft-lbs
Rear Caliper Guide Pins
27 Ft-lbs
Caliper Mounting Plate Bolts
74 Ft-lbs
• Front Brake Hose to Caliper Banjo Bolt
30 to 32 Ft-lbs
• Master Cylinder Mounting Nuts
21 Ft-lbs
• Rear Brake Hose to Caliper Banjo Bolt
22 Ft-lbs
• Rear Wheel Cylinder Bolts
1993 and 1994
115 in-lbs
1995 and Later
156 in-lbs
Suspension and Steering Systems
• Front Suspension
• Rear Suspension
Lower Control Arm Bolts
Through 2001
80 Ft-lbs
2002
87 Ft-lbs
Lower Control Arm Nuts
60 Ft-lbs
Panhard Rod
Models Through 1999
Upper Bolt/Nut
61 Ft-lbs
Lower Bolt/Nut
61 Ft-lbs
2000 and Later
Bolts
87 Ft-lbs
Nuts
55 Ft-lbs
Shock Absorbers
Upper Nuts
156 in-lbs
Lower Nuts
66 Ft-lbs
Stabilizer Bar
Clamp Bolts
18 Ft-lbs
Link Bolts/Nuts
16 Ft-lbs
Torque Arm
At Transmission
Nuts
30 Ft-lbs
Long Bolts
37 Ft-lbs
Short bolt
20 Ft-lbs
At Rear Axle
Bolts
96 Ft-lbs
Nuts
97 Ft-lbs
• Steering
Steering Gear Bolts/Nuts
63 Ft-lbs
Tie-Rod End Castle Nuts
35 Ft-lbs + up to an 1/6 additional turn, or 52 Ft-lbs maximum
to allow cotter pin to be inserted. Don not back off castle
for cotter pin insertion.
Steering Shaft U-Joint Pinch Bolt/Nut
35 Ft-lbs
Steering Wheel Nut
32 Ft-lbsEverything has been triple checked, I got it out of my repair manuals. Make sure you clearly read if the specification is Ft-lbs or in-lbs because we dont want no lose or broken bolts/nuts. If you see something I dont have in here either contact me and I will put it in.
* = degrees
General
• Spark Plugs
(3800)144 in-lbs
(3.4L)23 Ft-lbs
• Wheel Lug Nuts
(3800)100 Ft-lbs
(3.4L)100 Ft-lbs
3800 Engine
22 Ft-lbs
132 in-lbs
1998 and Earlier
1999 and Later
18 Ft-lbs
Through 1999
48 in-lbs
2000 and Later
96 in-lbs
1998 and Earlier
106 in-lbs
1999 and Later
1999 and Earlier
132 in-lbs
2000 and Later
132 in-lbs
132 in-lbs
Water Outlet Bolts
20 Ft-lbs
Side Bolts
22 Ft-lbs
1997 and Earlier
22 Ft-lbs
1998 through 2001
2002
22 Ft-lbs
• Oil Pan Bolts
125 in-lbs
• Oil Pump
98 in-lbs
132 in-lbs
• Valve Cover Bolts
89 in-lbs
22 Ft-lbs
22 Ft-lbs
3.4L Engine
216 in-lbs
58 Ft-lbs
37 Ft-lbs
96 in-lbs
96 in-lbs
216 in-lbs
61 Ft-lbs
22 Ft-lbs
Studs - 53 in-lbs
30 Ft-lbs
216 in-lbs
• Valve Cover Nuts
89 in-lbs
37 Ft-lbs
(3800)21 Ft-lbs
(3.4L)21 Ft-lbs
(3.4L) Long Bolts
33 Ft-lbs
Short Bolts
192 in-lbs
Small Bolts
89 in-lbs
(3800)115 in-lbs
(3.4L)216 in-lbs
(3800)
(3.4L)18 Ft-lbs
(3.4L)18 Ft-lbs
(3.4L)20 Ft-lbs
• IAC Valve Screws
(3800)27 in-lbs
(3.4L)30 in-lbs
28 Ft-lbs
156 in-lbs
30 Ft-lbs
55 Ft-lbs
70 Ft-lbs
46 Ft-lbs
Through 1999
2000 and Later
1997 and Earlier
All Except 3800 V6
15 Ft-lbs
3800 V6
71 in-lbs
1998 and Later
71 in-lbs
20 Ft-lbs
14 Ft-lbs
Through 1999
50 Ft-lbs
2000 and Later
37 Ft-lbs
Through 1999
96 in-lbs
2000 and Later
27 Ft-lbs
15 Ft-lbs
Front
106 to 115 in-lbs
Back
97 in-lbs
1997 and Earlier
38 Ft-lbs
1998 and Later
23 Ft-lbs
27 Ft-lbs
74 Ft-lbs
30 to 32 Ft-lbs
21 Ft-lbs
22 Ft-lbs
1993 and 1994
115 in-lbs
1995 and Later
156 in-lbs
• Front Suspension
Balljoints
Lower Ball Joint Nuts
81 Ft-lbs
Upper Ball Joint Nuts
39 Ft-lbs
Lower Control Arms
Front Bolts/Nuts
74 Ft-lbs
Rear Bolts/Nuts
85 Ft-lbs
Shock Absorber/Coil Spring Assemblies
Upper Nuts
32 Ft-lbs
Upper Bolts
37 Ft-lbs
Lower Bolts/Nuts
48 Ft-lbs
Stabilizer bar
Clamp Bolts
41 Ft-lbs
Link Bolts/Nuts
17 Ft-lbs
Upper Control Arms
Control Arm to Support Bolts/Nuts
72 Ft-lbs
Upper Control Arm Supports
Nuts
32 Ft-lbs
Bolts
37 Ft-lbs
Hub and Bearing Assembly(front) Mounting Bolts
63 ft-lbs
81 Ft-lbs
39 Ft-lbs
Lower Control Arms
Front Bolts/Nuts
74 Ft-lbs
Rear Bolts/Nuts
85 Ft-lbs
Upper Nuts
32 Ft-lbs
Upper Bolts
37 Ft-lbs
Lower Bolts/Nuts
48 Ft-lbs
Stabilizer bar
Clamp Bolts
41 Ft-lbs
Link Bolts/Nuts
17 Ft-lbs
Upper Control Arms
72 Ft-lbs
Nuts
32 Ft-lbs
Bolts
37 Ft-lbs
63 ft-lbs
• Rear Suspension
Through 2001
80 Ft-lbs
2002
87 Ft-lbs
60 Ft-lbs
Panhard Rod
Models Through 1999
Upper Bolt/Nut
61 Ft-lbs
Lower Bolt/Nut
61 Ft-lbs
2000 and Later
Bolts
87 Ft-lbs
Nuts
55 Ft-lbs
Shock Absorbers
Upper Nuts
156 in-lbs
Lower Nuts
66 Ft-lbs
Stabilizer Bar
Clamp Bolts
18 Ft-lbs
Link Bolts/Nuts
16 Ft-lbs
Torque Arm
At Transmission
Nuts
30 Ft-lbs
Long Bolts
37 Ft-lbs
Short bolt
20 Ft-lbs
At Rear Axle
Bolts
96 Ft-lbs
Nuts
97 Ft-lbs
• Steering
63 Ft-lbs
35 Ft-lbs
Steering Wheel Nut
32 Ft-lbs
