Engine temps all over the place - FirebirdV6.com/CamaroV6.com Message Board
  • Engine temps all over the place
    Hi,
    I have a 1998 Firebird, and the other evening while driving around I noticed that the engine temperature gauge was fluctuating a lot....normally it doesn't get much higher than 210 and consistently runs cooler than that.
    But it was getting really hot, close to 260. It kept moving around between 260 and 160. Anyways I've never had this happen before, so any ideas on what's happening? Thanks!
    Check your coolant. If the needle is accually jumping then it sounds like an electrical problem maybe?
    <b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
      The coolant level was ok....I hope it's not electrical but it sure sounds like it. Yeah, the needle was moving back and forth....even tonight, it got all the way to the red mark and the "check gauges" light came on! I just blasted the heater and it went back down.....
        Check and probably replace your thermostat and make sure that your coolant fan(s) are coming on when the temperature raises. Do coolant flush and refill. Other then that then a possible electrical problem. Their could be a couple of things wrong in combination. Check them out. Good luck.
        1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
