taking rearview mirror off - FirebirdV6.com/CamaroV6.com Message Board
  • taking rearview mirror off
    i gotta take the rearview mirror off. whats the trick without breaking it ? thanks
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
    Re: taking rearview mirror off
    There is a small set screw (also know as internal wrenching or allen key screw) in the mirror attach base at the windshield. I can't remember the size, maybe 1/16 or 3/32 in.
    Insert allen key into set screw, loosen off the set screw, then slide the mirror assembly in an upward direction. It will slide off the window mount that is glued to the window.
    To install, reverse the above procedure.
      dont think mine has a set screw. thats what i orig thought
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      A Few Mods....
        Really? I've haven't seen a GM without one!
        It's really small and black just like the base that it's screwed into. So it isn't the most obvious thing.
        My mirror fell off last year and I had to re-glue the window mount pad. My car is a 99 FB and the mirror does have a set screw.
          can u get me a pic ? i didnt see any screw on mine
          1997 Camaro LS1 RS
          1994 Camaro - Sold
          A Few Mods....
            on my 2000 camaro and 2000 Bonneville there is no screw
              I have a torx screw on mine, but it's covered up by a small piece of plastic.
                got it. just hadda twist the whole mirror and it popped off.
                1997 Camaro LS1 RS
                1994 Camaro - Sold
                A Few Mods....
                  Arent you going to get a ticket like that?
                  Any ways, some crazy weather over here, im pretty sure its gonna be 65* tommorow over in Bay Shore we should go riding sometime.
                    replacing the mirror. cant go cruisin i just sent off my pcm to texas speed :(
                    1997 Camaro LS1 RS
                    1994 Camaro - Sold
                    A Few Mods....
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
