spark plug gaps - FirebirdV6.com/CamaroV6.com Message Board
spark plug gaps
  • spark plug gaps
    does anyone know what the recomended gap distance is for the sparks? its a 99 3.8
    Re: spark plug gaps
    .06" gap
    does anyone read their manual anymore?
      Re: spark plug gaps
      I do!:) Just another reason to buy a chiltons too, it tells you everything.
      '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
      '99 Firebird SOLD 1/4 mile 15.4 @ 86
      '66 Ford SOLD
        Re: spark plug gaps
        hell no
        2000 3.8 A4 Pewter Camaro
          Re: spark plug gaps
          There's a manual?
            Re: spark plug gaps
            nor do they search
              Re: spark plug gaps
              Originally posted by bbplayer133 View Post
              .06" gap
              .06 gap, does it matter if they're standard plugs or iridium? I've got a 2000 3.8 V6 Firebird, not going to be spraying, but thought I'd ask.
                Re: spark plug gaps
                If you want to spend the extra money and if they will last longer so you don't have to changed them for along time then its up to you.
                  Re: spark plug gaps
                  Good thing we aren't going by a blue print drawing. .06 is plus or minus .02.
                    Re: spark plug gaps
                    Some guys run NGK TR55's which are .055 gap N/A and like them also.
                      Re: spark plug gaps
                      Usually when you buy them they would already have been gapped for you depending on the brand though.
                      But .06 with a -/+ .02 seems to be the cardinal rule.
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
