Car starts then 1-2 seconds later falls on its face and shuts off. Help - FirebirdV6.com/CamaroV6.com Message Board
  • Car starts then 1-2 seconds later falls on its face and shuts off. Help
    Well I was driving to a car show and got there and parked it......then an hour later i go to start it and it starts up and 1-2 seconds later is goes blub blub blub and falls on its face and shuts off. Does this everytime i start it......fuel pressure seems low. I changed fuel filters and still does it. Whats it sound like to u??
    [ October 06, 2002: Message edited by: Shane ]</p>
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
    anyone have any idea????
    Past Ride
    Current Ride
      Hey, This is my first post, I've been visiting this board for 6 months or so, but never posted.
      I had the same problem, but the fule pressure was fine on my car, I switched out plugs and wires and it got rid of it. since you have low fule pressure I'm guessing that the problem is something else but you never know.
      1998 3.8 M5 Navy Blue<p>SLP UltraZ hood,<br />Ram-Air box off a 1998 WS6 Formula, K&N, JetChip stage 2, Boral Cat-Back, Hurst Short Shifter<br />BMR strut tower brace, BMR 32mm front swaybar w/ poly bushings, BMR 21mm rear swaybar w/ poly bushings, QA1 adjustable front struts/coil-overs, QA1 front springs, Ground Controll rear coil-overs, Eibach rear springs, Rear end w/ 3.42 gears and LSD off a 1999 Trans-Am, Taylor 8mm Plug wires, Powerslot Sloted cross-drilled rotors, Tenzo-R Black and Grey seats, G-Force 5 point belts<br />RK-sport 4 point rollcage, Sony Mini Disk head unit, Blue under-cariage Neons, Firestone Firehawk 255/55/16
        plugs and wires are new
        Past Ride
        Current Ride
          Check under the hood to make sure everything's all plugged up tight.I had the same problem and it turned out that one of the plugs on my wiring harness was backed out just a little and it would start slightly and then stumble and die.Not sure if that'll help,but good luck.
          Kevin
          1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
            But i dont get it....i got in it and drove to a parkin spot and parked it and came back an hour later and it started doing this. :(
            Past Ride
            Current Ride
              Fuel Pump dying?
              I had NO problems what so ever until one day it just Cr@ped out on me. I was driving, everything going good, then it started choking and died. Waited a few mins, fired right up, drove a few more blocks, same thing. Took me about 2 hrs to drive 2 miles back to my house, car kept on dying after a few feet.
              Thats what I would look into, fuel PUMP. Good luck.
              <a href=\"http://www.pbase.com/danny83/car_pix\" target=\"_blank\">http://www.pbase.com/danny83/root</a><br /><a href=\"http://community.webshots.com/user/ttopbird96\" target=\"_blank\">http://community.webshots.com/user/ttopbird96</a> [/URL]<br />00 NMB Formula M6<br />323.4HP, 336.5TQ<br />Lid, Filter, Cutout, all else stock :)<p>\"Let the modding begin!\"
                LOL......check you IAT sensor also, make sure its plugged in. Don't ask me how i know. [img]graemlins/rofl.gif[/img]
                Scott
