Brake Light - FirebirdV6.com/CamaroV6.com Message Board
Brake Light
  • Brake Light
    1997 Camaro 3.8
    So my driverside brake light wont work. I replaced the bulb and it still wont work. What the hell? Fuse? Passenger one works just fine.
    Re: Brake Light
    how does the socket look? is it burnt or corroded? I would get a manual and a test light. :)
    2000 3.8 A4 Pewter Camaro
      Re: Brake Light
      You might have also replaced it with a burnt out bulb too.
        Re: Brake Light
        i've done that... with 3 different bulbs .. i knew something was wrong
          Re: Brake Light
          Make sure the socket is very clean and has no corrosion. Also, try taking the replacement bulb you bought and putting it in your passenger side and taking your passenger side one and putting it in your driver's side. Then see what happens.
