1997 v6 engine swap question - FirebirdV6.com/CamaroV6.com Message Board
  • 1997 v6 engine swap question
    Putting an lt1 into my 97 bird. All is well but the v8 mounts don't bolt up to the k-member.. does anyone make a motor mount conversion kit?
    No....you must have a LT1 k-member.
      bmr makes a nice lightweight tubular K-member, but its around $500 i think
      www.bmrfabrication.com
      \'01 Mineral Grey SVT Cobra<br />-former F-body owner
        yeah, i figured as much...thank you both for the info
          Still trying to find oil leak
          3 days ago
          Getting some work done on my truck
