went to autozone today and got 2 codes left out of 6 i had b4 i got inspected...1 code reads egr performance and the other reads 4x4 lamp circiut short to battery what the hell is that?? and what can i do?
2 codes left...HELP???
Re: 2 codes left...HELP???
A P1870 code means the transmission is seeing a slip condition. Sometimes it points to the TCC clutch not working properly. Sounds like the transmission needs to come out. See if you can get hold of a GM diagnostic chart for this code and it will make more sense to you.
P1406 EGR Valve Position Sensor Performance. Check for carbon buildup
I just copied these so don't quote me as factLet's flip a coin. Heads I get tail, Tails I get head.
Originally posted by 96greenmachinep1870
p1406
autozone is stumped about the transmission code its not a 4x4 for petes sake!
p1406- EGR is failing. Not sure why they told you crap about 4x4 lighting circuit, lol. Either the tube is plugged with carbon or the EGR is not opening properly anymore. You can delete this and use a egr sim from zzperformance.com or block it off and tune the code out with hptuners. Or buy a replacement EGR either used or new.Last edited by 97rs4life; 01-10-2007, 09:32 PM.
Originally posted by 97rs4lifep1870- time for the sonnax valvebody upgrade to your trans. My bro had to do it last year to his firebird. Very common problem with our 4l60e trans and there are tons of threads on this. Doesn't mean your trans is shot, but it is something you want to fix before it does effect your trans down the road.
Originally posted by 96greenmachineis all this expensive? what are the prices for the egr sim and transmission upgrade? sry bout the last post it was a lil late lol
egr sim and block off plates run about 80 buck I think from zzp. Unless you find a used egr or something. New egr's are pretty expensive.
u can wait a little while, but I would do it as soon as you can afford it. Your 1-2 shift will get worse and worse if u don't. On long trips the code will come up again.
Originally posted by 97rs4lifeuse a egr sim from zzperformance.com or block it off and tune the code out with hptuners. .1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
Originally posted by Tom RsDONT USE THE SIM !!! i used it and my car threw a p1406. its trash. get it tuned out thats what i did
Originally posted by 97rs4lifethen he would have to buy a 97 pcm which would cost even more though. I haven't heard to many people say the sim didn't work. Maybe you had a defective one or something.
Originally posted by 96greenmachineugh more money? no way cant afford a pcm either lol if i had my way ide get rid of all this emission :bs: its really stupid this doesnt do much for pollution anyways...:rant:
anybody know the emission exempt rule? as in the car or truck being a certain age or what not? i always thought that if it was 25 years or older it was exempt but now my brother tells me he heard that if the car came with emissions related componets it has to have them on the car...
