Hypertech Programmer Update - FirebirdV6.com/CamaroV6.com Message Board
  • Hypertech Programmer Update
    Its been a week, 400 miles, and I've learned a lot.
    #1 - Our cars will fly. I went so far past the 125 mark on my Camaro down I-10 the other night I was into the voltage gauge, I just let off before I got a ticket. I was shifting out of 4th near redline so I had to've been doing around 135 or better... so indeed the limiter is gone. [img]graemlins/thumbsup.gif[/img]
    #2 - (Good, but bad)
    Good = My thermostat is working wonderfully, and the fans are working wonderfully, and the car never gets hot anymore even in traffic - its great. Its fun seeing the temp gauge drop to the low side of the 2 (on the 210) driving down the highway... my fuel economy was around 32mpg @ 90 last night too - I never saw over 26/27 with the 195 stocker stat. [img]smile.gif[/img] Thumbs for thermal efficiency!
    Bad = the 2002 programming is still there, somewhere, and sadly after about 250 miles of driving it still kills the temp gauge and kicks the fans on high :mad: I'm calling Hypertech to see if they can fix this for us 2002 owners (do 2001s also suffer from this?!?).
    #3 - the programming seems to have given me a power boost, its most noticeable when passing on the highway. Partial throttle response is a lot better. I switched back and forth from stock to the 87 octane programming a few times and took trips trying to see if I felt a difference - I do and its worth it.
    I'll get a dyno done as soon as I can get this thermostat stuff resolved. Also, if anyone who doesn't plan on running below a 180° stat would like to swap me their 2000 M5 PCM, I will pay you money for it and send you my 2002 PCM free. Please contact me at dgo610@comcast.net if you would like to swap.
    [ October 06, 2002: Message edited by: Dominic ]</p>
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
    Bad = the 2002 programming is still there, somewhere, and sadly after about 250 miles of driving it still kills the temp gauge and kicks the fans on high I'm calling Hypertech to see if they can fix this for us 2002 owners (do 2001s also suffer from this?!?).
    My 2K1 does exactly the same thing and has for seven months. Had to switch to a 180 thermo.
    2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
      Thanks, monday I will mention that the 2001s ALSO do this so we can kill both birds *heh* with one stone.
        Turns out Hypertech acknowledges this information as truth and recommends running a 180 stat in 01s and 02s :mad: I guess I'll run a 180, at least with the hypertech I can lower my fan turn on temperatures to match it [img]smile.gif[/img]
        [ October 08, 2002: Message edited by: Dominic ]</p>
          or you can wait on a 2k pcm ;)
          1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
            <blockquote>quote:</font><hr>Originally posted by TheBlackSwordsMan:
            or you can wait on a 2k pcm ;) <hr></blockquote>
            So hard to find - I really would like one though. I'll pay for one or trade my 2002 for one anyday someone is willing.
              thats really weird... my 160* stat is working fine... it killed the temp gauge twice and hasn't since... i guess because its so hot here in SA TX... i dunno, man i want the hpp3 bad... im gonna have to get one soon...
              merlin
              2002 Firebird<br />2003 Yamaha YZF 600R
                So, you run the 160 stat in your 2001 or 2002 successfully? How long did you wait (say you drive evey day, perhaps in miles) for the gauge to come back and act normally? How long did it take to adapt to the 160?
                  <blockquote>quote:</font><hr>Originally posted by Dominic:
                  I switched back and forth from stock to the 87 octane programming a few times and took trips trying to see if I felt a difference - I do and its worth it.<hr></blockquote>
                  One question... why not the 93 octane progamming?
                  Matt<br />2000 Firebird<br /><br /><a href=\"http://www.fullthrottlev6.com/forums/index.php?\" target=\"_blank\">FullThrottleV6.com</a>
                    <blockquote>quote:</font><hr>Originally posted by HAZ-Matt:
                    <hr></blockquote>
                    I haven't tried it, but according to the dyno chart they only gained 1-2rwhp from the 93. The 87 provided nearly 10rwhp increase alone.
                      I guess I'll run a 180, at least it will fix my fan turn on temperatures right?
                      The 180 fixed my fan and temp gauge problem.
                        so, how can i get my car up past about 115 when it shuts off (govern). I have a 3.4L '95 camaro and feel like i could go quite a bit faster seeing as the rpm range is far from the redline in 4th gear (A4 trans)at 115. I feel like i'm still accelerating when it stops on me. I'm just not sure which products are out there to do the trick for the 3.4 successfully, without any harmful or annoying side effects.
                        Any help?
                        2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
                          How well would the timing advance work if let's say you replaced the rockers? (or cam)
                            <hr></blockquote>
                            have you dyno-proven this gain because if that's really how much you gain, I'd love to get this thing (along with a 2K PCM of course [img]tongue.gif[/img] )
                              I put a 160* thermostat in my car a LONG time ago. My temp gauge never died and i put it in the same time i power programmed it. It wasn't until i put z28 guages in my car that it died for a min or 2 and then came back on, then it died the next day until i reprogrammed it again. Now it's been a little over a month and it hasn't died since. If it does I'll just reprogram it again.
