Just following the trend...BLLdogg - FirebirdV6.com/CamaroV6.com Message Board
  • Just following the trend...BLLdogg
    P0153 Heated Oxygen Sensor (HO2S) slow response Bank 2 Sensor
    P1133 Heated Oxygen Sensor (HO2S) insufficient switching Bank 1 sensor 1
    P1153 Heated Oxygen Sensor (HO2S) insufficient switching Bank 2 sensor 1
    "Supporting" these codes:
    P0171 Fuel trim system lean Bank 1 x2 ( 1 pending. )
    P0174 Fuel trim system lean Bank 2
    P0300 Engine misfire detected x2 ( 1 pending. )
    Any ideas? I have an O2 simulator for the downstream, and it's never caused any problems yet...should I suspect this one?
    Re: Just following the trend...BLLdogg
    figure out why you are going lean. do you have a vacuum leak? is the fuel pressure strong and steady? evap leak?
    2000 3.8 A4 Pewter Camaro
      I seriously have been really busy, and the weather has been non-stop raining. But when I start my car ( keepin' the oil fresh through the motor!! ) I notice at first, it idles smoothly, but after it runs off choke(I think it does at least), it seems to start missfiring then...helpful info? I noticed after I shut it off after she miss fires, and start her right back up, she miss fires a little worse.
        have you tried new o2s?
        Follow me!
        Or this
          not even yet. still in the process of fixing my suspension system.
