This is nuts. The other day my blinker didn't come on, instead it was a solid green light. So I think, no big deal, I will just replace my blinker light. Well apparently, its not the easiest thing to get to, so after taking out my headlight, I easily replace the nasty bulb. Now I hit the Hazards to test... Wtf? My front blinkers alternate instead of coming on at the same time (the best way to describe it is to think of a police car (which I don't mind)). So now I try the left blinker. No work, just a solid green light. I hold the blinker handle down and the rear bulb works however, but it doesn't blink. I am confused as hell. Why are my front alternating? I know the front works because the hazards work, but why wont the blinker work?
Fix my blinker! haha
Re: Fix my blinker! haha
Sorry for the confusion. I realize it could have been written better although I was heading out the door when I posted this and was in a hurry. It is a 98 Camaro and I got the new bulb put in. Let me try to clarify some stuff.
-I replaced the bulb
-The right blinker works fine
- Since I have replaced the bulb the front blinkers (when in hazzard mode) will alternate like a police car.
-The left blinker does not work, but the front left bulb obviously still works considering the hazzards still work.
-When I click the left blinker all I see is a solid green light on the blinker indicator on the dash and nothing happens with the blinker.
-If I lightly press the blinker switch (so it doesn't keep blinking, just enough for a blink or two (hard to explain)) the rear blinker will stay on as long as I am holding down the switch.Last edited by Stock98camaro; 01-12-2007, 11:26 PM.Red 1998 Camaro<br />Mods so far=<br />K&N
blinker fluid is only $2 bucks, come on!2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
could be a fuse?
oh and the turn signal lights are easy change them from under the car you dont have to take the headlight out just in screw 2 bolts on that piece of plastic under the car and it should be a little flap and you can just reach your hand up in it and get the bulb out the wire is long enought that you can bring it out throught the flap and change it and just put it back in, you did alot of work just taking the headlight out
Originally posted by homedog119could be a fuse?
oh and the turn signal lights are easy change them from under the car you dont have to take the headlight out just in screw 2 bolts on that piece of plastic under the car and it should be a little flap and you can just reach your hand up in it and get the bulb out the wire is long enought that you can bring it out throught the flap and change it and just put it back in, you did alot of work just taking the headlight outRed 1998 Camaro<br />Mods so far=<br />K&N
Originally posted by Stock98camaroWhat fuses can I check? Also, replacing the bulb isn't the problem. The problem is getting them to work as a blinker. Maybe I should take video of it and let yall see for yourself. Brb, gonna make a video.
may not be a fuse...may be the actual relay for the blinkers...1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
yeah, but the same relay controls both right and left, so i doubt it is the relay, do you by chance have LED bulbs, because i know for a fact when i put LEDs in some wierd *** **** happened, when i would turn on the left turn signal all my interior lights would flash with it, but the right worked fine, i switched to incandecent and everything went back to normal
Originally posted by bahyeah, but the same relay controls both right and left, so i doubt it is the relay, do you by chance have LED bulbs, because i know for a fact when i put LEDs in some wierd *** **** happened, when i would turn on the left turn signal all my interior lights would flash with it, but the right worked fine, i switched to incandecent and everything went back to normalRed 1998 Camaro<br />Mods so far=<br />K&N
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
