I put my new spark plug wires in and im not sure if i put them in the right ones i took one out and then i put a new on in with the longest to short on the left and then longest to short on the right side but im not sure if they are going to the right COILS someone please help i just tryed startin my car and it had a hard time then i hear a kinda pop noise so i didn't try anymore If someone can tell me what goes to what cause none of the coils have numbers on them .. cause they are new ones .. Damn it
I need help RIGHT now!
Re: I need help RIGHT now!
mine is a 94 ... but what you say kinda doesn't work for me i know thats your firing order but i dont know what spark plug that is haha im sorry its really hard to understand you ... Maybe if you can tell me which spark plug goes to what coil??Last edited by Thefbomb13; 01-13-2007, 02:45 PM.
If you are looking at the coil pack it would be 6, 3, 2, 5, 4, 1 from the front of the pack to the back, the numbers representing your plug and/or wires.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
The odd numbers are on the drivers side and even on the passenger side. The numbers run from fronto back. So it would be 1, 3, 5 on the drivers side and 2, 4, 6 on the passengers side. Hope this helps.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
If you have a 3.4 your coils are 1,4,6,3,2,5 this is from left to right if you are standing in front of your car looking back. You cylinders would be 1,3,5 on the passenger side and 2,4,6 on the drivers side.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
This is not the firing order, this is the lay out of the coils and cylinders. The firing order is different. But you really don't need to know the firing order with our kind of set up. Firing order is used with a destributor cap, where the button will go around in order, so there for the wires would have to be layed out in the firing order.2000 Firebird A4, 3.42 LSD, K&N, Free Cold Air, PaceSetter, 3" in/out Catco, 3" S-Pipe, 3" Intermidiate Pipe, 2.5" Flowmaster 80
Originally posted by gman2000This is not the firing order, this is the lay out of the coils and cylinders. The firing order is different. But you really don't need to know the firing order with our kind of set up. Firing order is used with a destributor cap, where the button will go around in order, so there for the wires would have to be layed out in the firing order.
