I am having problems with my car, I've searched around the board but couldn't find anything to tell me the exact symptons of my problem. I am not running an SES light. My recently had the plugs changed and the wires checked, those are fairly new. When I accelerate the car runs fine, but when i push the pedal harder, it stumbles a bit. The car does not run well when i try and accelerate hard. At first an SES light came on, so i checked the wires and it was loose, so i tighten it and the light came off and it ran Ok for a bit. Now its doing this stuttering thing on hard accelerations. My thoughts were maybe O2 sensor, or fule filter or something. I am not sure waht the symptons for those problems are, could anyone describe them?? I used those fuel injector cleaner things, but not much improvement.
fuel or O2 symptons, HELP!!!
2005 Chevrolet Corvette C6 <br />M6, Magnaflow\'s 14336<br /><a href=\"http://community.webshots.com/user/v6purplebird\" target=\"_blank\">C6 Pics</a><br /><br />Old car:<br />1996 Firebird A4<br />SLP Cold Air Intake<br />Magnaflow Catback Exhaust<br />Magnaflow Catalytic Converter<br /><br />George Mason University<br />CEIE Major<br />Pi Kappa Alpha<br /><br /><a href=\"http://members.cardomain.com/nsolano\" target=\"_blank\">Firebird Pics </a>Tags: None
you might want to check the connections on the coils for rust mine did that after I had a wire come loose just corroded a little bit and was not making a good connection (Pita to find) also check your coil packs I just had to replace one of those also.Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
ok, thanks for the help. I will check the wires now, but how do i make sure the coils are running fine?? is there a device to check it?2005 Chevrolet Corvette C6 <br />M6, Magnaflow\'s 14336<br /><a href=\"http://community.webshots.com/user/v6purplebird\" target=\"_blank\">C6 Pics</a><br /><br />Old car:<br />1996 Firebird A4<br />SLP Cold Air Intake<br />Magnaflow Catback Exhaust<br />Magnaflow Catalytic Converter<br /><br />George Mason University<br />CEIE Major<br />Pi Kappa Alpha<br /><br /><a href=\"http://members.cardomain.com/nsolano\" target=\"_blank\">Firebird Pics </a>
