I have looked and looked for a fuse for the ciggarette lighter on my g/f's 97 firebird v6 can someone plz help. Its not working and the wire has no juice.
Where is the fuse?
Re: Where is the fuse?
you can't find the fuse? or you can't find the fusebox? fusebox is on the left side of dash that is covered when the door is closed, you have to pull off a panel... if you just can't find the fuse... There should be labels on the fusebox cover, if not look in the owner's manual... of that doesn't work, then start pullin fuses to see if any are bad...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
