My dad is a GM Certified Tech, only replace your spark plugs with factory ones, If a car has a running problem similiar to yours, this is one of the first things they check and replace if they are aftermarket. Also what year is your car?
Help with Dying camaro!!!
obviously something is wrong with the fuel system, the psi when Key on Eng off is supposed to be within 49-55 psi and hold! Mine is way low (and listed above) I'm gonna go ahead and replace the FPR, I'll tell you if it fixes it, hope autozones got em in stock.
thanks again99 camaro, white, taylor wires. Lots more soon.
Originally posted by Razzer:
My dad is a GM Certified Tech, only replace your spark plugs with factory ones, If a car has a running problem similiar to yours, this is one of the first things they check and replace if they are aftermarket. Also what year is your car?www.turbov6camaro.com
1997 3800 Series II Camaro
