car running rough - FirebirdV6.com/CamaroV6.com Message Board
car running rough
  • #31
    Re: car running rough
    ok it really sucks being at school and not being able to test plausible causes of my misfire while im at school, so far i havent had time to do any diagnosing the only other thing i have noticed is that when i start the car when its bone cold it runs for bout 5 seconds than the motor dips a little like the fan is kicking on and then the SES light comes on, so i got out and sure enough the rad fan is on and the car def has no temp yet, the guage appears to be working, could a faulty temp switch be causing my car to be running rich and the fan kicking on or am i just dreaming stuff up?? any speculations are welcome i am making a list of things im going to test when can go home :(
    76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
    89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
    • #32
      get the code scanned I dont know much from your description
      • #33
        I love when people want help from others but won't take the time to get their code scanned. And they wonder why no one has a solution.
        • #34
          CAR IS NOT REGISTERED YET!! i bought the OBD 1 code reader, it didnt work im going to try grounding the two prongs in the ALDL and see if that makes the SES light flash, i expalined symptoms earlier in the thread, ive searched this site and came up pretty empty handed, all im looking for is some possible causes that i can test when i am at home im not used to this OBD ****, i am used to working on my carbed 76 alot easier to diagnose and repair
          • #35
            if my ****ing SES light would blink i would have a much better chance of diagnosing what is wrong it dosent even blink code 12 to signify everthing is functioning ive explained this earlier in the thread!!!
            • #36
              if the rpms drop after 5 seconds of starting it that is normal
              • #37
                no they just dip slightly and then pick up like when your fan kicks on which it is which shouldnt be happening when the car has been running for 5 seconds and its 45 outside correct? i know this is a sketchy thread cause i dont have a code to go off of right now but if i cant get a code out of it guessing is as good as i can do until i start testing things out
                • #38
                  you are correct
                  • #39
                    I'm sure you've already checked all the fuses and all grounds
                    • #40
                      no actually i did not, honestly i even taken notice to where the fuse block is on the car, is it under the hood on the driver side, like i said all i can do now is make a list of things to test and any help at all is greatly appreciated :)
