Grinding Noise - FirebirdV6.com/CamaroV6.com Message Board
Grinding Noise
  • Grinding Noise
    Now I have another problem. After I took my car up to northern California, which was a 10 hour trip up and 10 hour trip back, I keep hearing and feeling a grinding when I push the clutch in. It doesn't do it when I'm not moving. If I'm taking a turn, though, if I push the clutch in it will grind. It does it in every gear as far as I can tell, even neutral. The clutch fluid was a bit low, but I filled it up and it still does it. My dad thinks it might be either the linkage or I need to add some gear oil. Has anyone else had this problem? Any help is very appreciated.
    Also, my low oil light is always coming on. It goes off if I turn the car off then turn it back on. I was thinking it might have to do with the replacement dipstick I have in it right now, but I don't know. The oil is full. Any ideas on that one? Thanks.
    Re: Grinding Noise
    my low oil light comes on and off too very weird but it usaully does it when im low on oil though...about the clutch i have no idea mines an auto.
