it makes a weird noise under load like wooshing air, sounds like its coming from drivers side of car i will throttle and it will lag and make this noise and get really powerless. It does it up hills or at higher rpms under throttle feels like i let off the pedel? it started the day after a seafoam all 3 ways i used the brake booster line to feed it in. could i have a vaccume leak?
Does it do it on a cold start or only after its been running for 10 minutes or so? Also, does it backfire at all? Sounds like the same issue my old 3.8 was having about a week before it went boom.
